Pine Pitch on Down Jacket!
Do you have suggestions on how to clean or remove the pine pitch ?
My beautiful coat has many spots and I haven’t found anything to remove the stains.
Thanks much !
Ist dies eine gute Frage?
Thanks much !
I’d try Goo Gone, the yellow orange stuff. It works on paper/magazines it should be ok on fabric. It could leave an oil spot which might evaporate over time or probably come out in the wash. WD-40 another possibility.
War diese Antwort hilfreich?
Hi @bonstelle ,
Have you tried “rubbing alcohol” to see if this removes the pine sap stains, you didn’t say?
Before trying it on the stains, try swabbing a small area with a Q-Tip moistened with the rubbing alcohol, in a place where it won’t be noticed, just in case it affects the dye of the material.
thanks jayeff .. another great suggestion .. will try as well.
Thanks so much Mike madgic !
Very appreciated .. I will try it out !
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 133
