Zum Hauptinhalt wechseln
Vierte iPhone Generation. Die Reparatur an sich ist unkompliziert, aber Frontglas und LCD müssen gemeinsam ersetzt werden. GSM mit 8, 16 oder 32 GB Kapazität, Modell A1332 in schwarz und weiß.
2375 Fragen Alle anzeigen
Faster way to remove loudspeaker
The loudspeakers of my iPhone 4 have very low sound. I want to replace the loudspeaker, I am looking at the ifixit guide and I am wondering if there is a faster way.
If I remove only the docking connector, and two screws holding the enclosure, will that be enough? Is it necessary to remove the logic board?
I have never disassembled the iPhone 4 yet and I was wondering if someone has tried this shortcut, or it is completely impossible.
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
I did it my way with total success :)
The replacement was much faster and easier than removing the logic board and I did not feel I put any pressure on the board.
Thanks for your help.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
You can slip it out that way you described. Take off the screws for at least the lower part of the logic board, that way it will give you more "wiggle room." It does put a little more stress on the logic board and you are prone to breaking off the metal prongs on the antenna. That's why we don't recommend doing it that way on our guide. But it can be done.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thanks Scott, I will try and let you know if it worked or broke something in the process.
von
Antwort hinzufügen
lantzero wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 799
