Zum Hauptinhalt wechseln
Ring Video Doorbell Model No. 88RG000FC100
Why is my hardwired battery not trickle charging
I've had my hardwired ring doorbell almost a year a the battery has always been at 100%
Lately its been slowly dropping and not recharging. I've read on other forums that this was the cause of a firmware upgrade and ring knows nothing about it. Their tech support is really terrible. Anyone experiencing this?
Ist dies eine gute Frage?
Bewertung 4
2 Kommentare
Same problem. Don't know anything about a firmware upgrade, but after a year or so of staying charged, my Ring Doorbell plus battery depleted. When I checked, it had lost connection to the "solar charger", actually hardwired to a transformer. Rebooting the device and charging the battery restored the electrical connection and battery stayed charged, but gradually lost some charge. Then lost electrical connectivity again. I don't know if this is a problem with the unit, the battery, or the transformer (or a loose connection).
von
Yes, ours has been doing the same thing. I have taken it off twice in the past month and plugged it in to charge it…within days it is low again.
von
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
I have the same problem, even change transformer, still not charging or ring internal door bell, connected old transformer to a cord, plugged in power, have 24v out, vired directly to ring, nothing, still not charging. I think ring disabled it so you have to buy theirs solar charger... How is that legal? Maybe time to buy nest door bell...
War diese Antwort hilfreich?
Bewertung 1
If your Ring Video Doorbell is not ringing correctly or is no longer working, use the Ring Video Doorbell Won’t Turn On problem page for possible causes and solutions.
Most likely, this is a faulty battery problem. A Ring Video Doorbell requires at least 3,900 mV. Check the voltage received by the Ring device by opening the Ring app, selecting ‘Ring Pro’, and selecting ‘Device Health.’ If the Device Health page tells you that the Ring is not receiving sufficient voltage, use this Ring support page to make sure that the Ring Pro Power Kit is properly installed.
If your Ring Video Doorbell is plugged in, receiving sufficient voltage, and is not turning on, the device’s battery may be defective. Replace the Ring Doorbell’s battery using this battery replacement guide.
Bewertung 0
1 Kommentar:
I have wireless and we are constantly having to charge. We lowered everything
von
I had the same issue.H
However the week that I noticed that the battery was low, I had visitors over and there were a lot ins and out of the door. I disabled all notifications and sure enough battery porcentagem it went up again!
Bewertung 0
This product is not equipped to handle extreme winter conditions. I have had 1st and 2nd gen versions. The battery will not maintain a charge even when motion detection is turned off. Don’t buy this product if you expect it to perform in extreme cold temps.
Bewertung 0
Antwort hinzufügen
carolyndardani wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 50
Letzte 30 Tage: 207
Insgesamt: 19,344
