Zum Hauptinhalt wechseln
The Pocophone F1 is a mid-tier smartphone made by Xiaomi Inc, announced on 22 August 2018 in New Delhi, India.
51 Fragen Alle anzeigen
I send my phone to the local repairshop
I want change my battery and change its thermal paste..
and the repairman broke the phone signal cable connector.. the repairman said water corrode the connection between the cable from the board..
question : can water affect the internal electronic component? can it corrodes the connector? is replacing the motherboard is the answer?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hello, yes water damage can be the cause of many issues and is unpredictable - including damaged chips and connectors on the logic board. It can also worsen over time. Replacing the logic board should fix the issue, however other parts of the phone may still be affected if water managed to get to the logic board. It is also possible the repairman made an error, but his theory is certainly possible.
Hope this helps (:
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
risinghopper wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 11
Insgesamt: 79
