Zum Hauptinhalt wechseln
The XPS 13 9360 is a 13-inch laptop released in 2016 with a 7th-generation Intel processor inside. It was updated in 2017 with an 8th-generation processor.
How can I replace this part?
Hello there guys!
What is the name of this part under the hinge? And how can i replace it? It seems very hard.
I have a dell xps 13 9360
Can a super glue work? If yes which super glue you know is very strong?
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
It's kind of hard to see the ammage. Is that part of the connector that came off? That would require solder, not glue. You're better off replacing the cable if that's the issue.
von
Thanks you so much for the answer, the broken part belongs to the palmrest, i am not sure if a strong glue can hold it back, or should i replace the whole thing.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @alberttio
The answers in this link may help you decide what to do.
Display hinge broke from base
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Albert wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 302
