Zum Hauptinhalt wechseln
Dieses Gerät hat mehr Features als ein einfacher Controller, wie zum Beispiel abnehmbare Thumbsticks und einen Steuerkranz aus Metall. Der Controller wurde primär für eine Nutzung mit einer Konsole konzipiert, er kann aber auch am PC genutzt werden.
62 Fragen Alle anzeigen
Why does the right trigger activate without touching it
My brothers controller recently started to get the right trigger problem where it would constantly activate but the left trigger wouldn’t work is there anything that my brother and I can fix this problem.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
My RT and LT buttons press themselves and RB is acting like the start button. Also my right stick isn't doing anything. The ABXY buttons work perfectly fine though.
von
Einen Kommentar hinzufügen
1 Antwort
I've had controllers do this before. A sign that it's taking to much physical wear. Usually, a controller will do that when its hardware is resting on the internal components. Or the “middle man” component isnt doing its job because it is broken/worn or out of place. The only way to know would be to take it apart. Look for an internal part that gives the trigger resistance so it isnt ever resting on the internal button after you have applied pressure. Then see if it's the trigger itself by taking off the front controller plate and seeing if the button makes contact with the necessary button. If so, check the internal buttons to see if they are stuck or in a bind. Press them a few times and see if the console receives signal. Make sure everything is secure and safely reassembled.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Andrew Urquizo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 16
Letzte 30 Tage: 73
Insgesamt: 2,284
