Zum Hauptinhalt wechseln
Veröffentlicht am 16. September 2016. Modelbezeichnung 1660, 1778. Verfügbar in den Versionen: GSM oder CDMA / 32, 128 oder 256GB / Rosé Gold, Gold, Silber, Mattschwarz oder Hochglanz-Schwarz
2265 Fragen Alle anzeigen
Do iPhone 7’s naturally run hot?
I purchased a used iPhone 7 and replaced the cracked screen with a new one. It is in cosmetically almost mint condition now (housing was in very good condition), however have noticed that when 20Watt fast charging it and during use it can get quite hot near the logic board. The device hasn’t been water damaged (indicator is white) and the logic board is in visibly perfect condition with no signs of logic board repairs, and all parts appear to be Apple Original. Any ideas? I have another 7 as a spare that can also get quite hot when playing games so I don’t know if it is just a thing with the 7’s?! Thanks (:
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
iPhone 7 doesn’t support fast charging, the best it can do is about 7.5-10w.
Since we can’t be sure of your subjective experience of temperature, all we can do is ask you to get a known good iPhone 7 to compare, if they behave the same consistently, then it is normal.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Okay cool - I will try it against another 7 or 7 Plus if I can’t find one, and will use standard changing brick and see if that works better. Thanks!
von
Antwort hinzufügen
TmG wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 39
