Zum Hauptinhalt wechseln
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
497 Fragen Alle anzeigen
Washer stops agitating after a couple minutes.
I have an old as dirt washer and it's worked like a champ for 12 years for me (it was used when I bought it so it's even OLDER)
Anyway, I'm having an issue where the cycle starts, fills with water, agitates then a couple minutes if agitating it stops. I can hear the timer clicking but no motor sounds. If I pull the start and press it again it starts agitating again. Sometimes for 1-4 minutes then stops and I have to pull the start and press again to get the agitator to start. Any ideas on what it could be?
It drains and spins just fine, the only issue is that I have to stand there and constantly pull the start on of off to get it to agitate.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
If your Kenmore 110 Series Washing Machine refuses to spin or agitate during the wash cycle, see the Kenmore 110 Series Washing Machine Doesn’t Spin or Agitate problem page for possible causes and solutions.
Here is my previous answer on this issue:
Why will my washing machine not agitate?
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Try turning on deep clean
von
Antwort hinzufügen
Ruth C wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 27
Insgesamt: 818
