Zum Hauptinhalt wechseln
The Sony Xperia E5 is an Android phone which was released in June 2016. It features a 5.0-inch display with a density of 229 dpi and a 13MP rear camera.
black screen but reacts to touch
Hey, I needed a new microphone on my Sony Xperia E5 because it was broken, so I took the mobile apart, changed it and then put it together. When I pusched the power button it turned on but the screen was still black. The phone reacts to touch, charching works, sounds work. It is actually not totally black, in a dark room I can see whether it’s off or on. And also there is a small stripe of white light in the top of the screen. Does anybody have any idea what the problem could be?
Thanks.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @janast ,
Try shining a torch at an angle close to the display when the phone is on and check that you can see images OK.
If so then there is a backlight problem.
Check that the display flex cable is securely connected to the systemboard and also that there are no rips in the flex cable.
Did you disconnect the battery from the systemboard before starting the repair?
If not then you may have accidentally blown the fuse that feeds the backlight power to the screen.
I can’t find a schematic for the phone but in some other phones the smd fuse is mounted near to the flex cable connector. Worth a look anyway.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Janast wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 27
Insgesamt: 534
