Zum Hauptinhalt wechseln
The Ninja Professional Blender 1100 watt model BL663CO, is a high-performance blender used for ice crushing, blending and pureeing.
15 Fragen Alle anzeigen
Accidentally plugged into 220V outlet.
I accidentally plugged this blender to 220V..what should I do.?as of now..it’s not working..turns out its broken..how can i repair.?or just need to replace fuse.?if yes..what kind of fuse?thank you!
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Hi. Were you able to get it fixed? If yes, how did you fix it please? I'm currently in the same situation. Looking forward to your response.
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hello, the first thing you need to do is to replace the fuse, the rated voltage is written on it. But you can bypass it momentarily with a wire to check if everything works fine, which I do NOT RECOMMAND, especially if you’re not familiar with electronics.
War diese Antwort hilfreich?
Bewertung 1
The varistor in mine blew (yellow circle) 10s271k and can be replaced with 10d271k (blue circle)
Bewertung 1
Antwort hinzufügen
Ampong Bicol wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 57
Insgesamt: 847
