Zum Hauptinhalt wechseln
Modell A1311 / Mitte 2011 / 2.5 & 2.7 GHz Core i5 oder 2.8 GHz Core i7 Prozessor
432 Fragen Alle anzeigen
iMac 2011 power loss on start, LED 2 comes on before shutdown
Repairing an iMac (2011 A1311, 21.5 inch) I received and dealing with immediate power failure after turning on.
Already replaced power supply.
Power fails less than 15 seconds after startup. LED comes on then goes off on start up (sometimes doesn’t even do that).
LED 1 stays on when plugged in.
Assuming this is a compromised logic board, but not sure if it could be something else. (RAM? Power button? Cord?)
Thanks in advance!
UPDATE: (Weird)
I tried different used cords, all the same voltage (125, Volex) and it stayed on for longer, even got to Apple logo and started to load before it crashed to black again, LED 1 only.
Made it to LED 3.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Is the actual power turning off? Or is it the display turning off? My iMac has that exact problem where the display will turn off.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
The power itself. I’m troubleshooting without the display connected currently.
von
Antwort hinzufügen
Onlyififonly wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 33
