Zum Hauptinhalt wechseln
Das ist die LTE-Variante der fünften Generation des iPad, erschienen im März 2017. Erhältlich mit 32 und 128 GB Speicher, einem 9,7 Zoll Retina Display und einem 64 Bit A9 Prozessor.
Does the iFixt IPad 5th gen LCD replacement has a protective film?
I have received day ago my “new” LCD screen from iFixit.
My first impression is the LCD surface has scratches and dust, which is surprising because I ordered a NEW one. Also, I’m not sure if the scratches are over the protective film, because I’m not sure if it has one. There is no easy way to know if it comes with a protective film because it has no tabs to pull it over.
Does anybody has a recommendation?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
It more than likely has a protective film. If you get something like a toothpick or even fine tipped tweezers you can kinda get under it at one of the corners. Just did an iPad 6 LCD (which is also shared between the Air 1 and iPad 5) last week and it too had a film on it.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thank you Jesse!
Certainly it had a protective film.
Now I have to deal with a touchscreen issue... I have changed the LCD and the touchscreen and now the touchscreen is erratic, looks like the bottom quart of the screen is not responding.
Thanks again and take care!
von
Antwort hinzufügen
ferbarragan88 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 54
Insgesamt: 254
