Zum Hauptinhalt wechseln
Vorgestellt am 16. September 2016. Modelle A1661, A1784 und A1785. Verfügbar mit 32, 128 oder 256 GB internem Speicher in den Farben Rose-Gold, Gold, Silber, Schwarz, Diamantschwarz und Rot.
1364 Fragen Alle anzeigen
Can an iPhone really read the actual capacity (mAh) of the battery?
I just bought a battery. The seller claims that the battery capacity is 3300mAh. I just installed the battery, but the iPhone tells me that the battery capacity is just 2900mAh. The brand of the battery is MYPRO. The apps that I had used to check the capacity of the battery is CPU Dasher Mobile Master and CPU-x Dasher z Battery life.
  • Can the iPhone really read the battery capacity?
  • Is the capacity true, and the app/iPhone just incorrectly reports the capacity?
  • Are there really replacement batteries that have a higher capacity than the original battery on 2021? I had read Opinions What do you guys think of extended capacity batteries post, but it was on 2019, maybe there’s a new battery now?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
The iPhone 7 plus original battery has 2900mAh of capacity, I’d expect the software is calibrated accordingly. The only way to tell the real capacity is to discharge the battery down to its cutoff voltage and charge it via a good charger that will tell you how many mAh it was able to put into the battery. Modern chargers in the RC world do exactly that in order for one to see battery health.
Since the iPhone will tell you when the battery starts degrading (battery life remaining) there is some kind of measurement done by the phone. This could be simple by just counting charging cycles or more sophisticated by measuring mAh loaded as described above. If the latter is true and the phone software accounts for it then you might see a change in capacity after a few cycles. I doubt it however, why should Apple account for battery changes by third parties? If the capacity claim of the replacement battery manufacturer is correct, you most likely will just notice longer battery life.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
I think the iPhone simply counts the charging cycles, since the battery capacity didn't update, I already drained and fully recharged the phone 3 times already.
von
Antwort hinzufügen
Myles Earvin Uy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 38
Insgesamt: 963
