Hi,
Have you tried using a different charger or charger cable and checked if the phone now started to charge, you didn’t say?
Use a strong light and a magnifying glass to visually inspect the phone’s charge port to ensure that there is no lint etc lodged in the port enclosure that may prevent a good electrical connection which is maybe why the battery is not charging properly and therefore the phone won’t turn on. Also check that all the pins in the charge port are not damaged etc.
If there is any debris in the port enclosure, do not use a metal pin or probe to try and get it out as you may damage the pins or cause electrical problems in the phone. Instead try to clear it out by using a vacuum cleaner.
If the charge port appears to be OK then perhaps there may be a problem with the battery. Try replacing the battery and check if that resolves the problem.
Here’s a teardown video of your model phone that may help. It shows how to open the phone so that access to the battery is possible. The battery is be seen being disconnected at about 4:00 minutes into the video. Unfortunately the video doesn’t actually show the battery being removed but you should be able to work out how it is done.
Replacement batteries are available online. Just search for HTC U12+ battery to get results for suppliers that suit you.
If replacing the battery yourself seems too daunting, contact a reputable, professional mobile phone repair service and ask for a quote.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
0
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
I have a similar problem with my u12+. Did you find a solution as to the ultimate cause?
von D Roberts
@darob00 unfortunately not, left the phone for a couple of weeks and when I went to try again the new battery is now useless and won't even charge.....keep in touch if you have any luck
von Stephen Maginnis
Anyone of you two had luck with this one in the meantime? Unfortunately the same thing happened to me too today. It keeps on showing the white HTC logo, goes black and repeats over and over again :(
von David M
My phone dropped and could not get the phone on after. It did vibrate when pushing the power button at first. Plugging in the charger did nothing, no LED. Couple minutes later I found the phone getting warm so eventually opened it up and disconnected the battery. Visually went trough the phone ut found nothing except for a slightly warped microphone board due to previous repair. So I am also trying to figure out how to fix so I can at least save the data before moving on.
von Kevin de Kruijf
