Zum Hauptinhalt wechseln
The aluminum PowerBook G4 was released by Apple to replace the previous titanium-body model. The 12" and 17" versions debutted in January 2003 with the 15" version following in September of that year.
683 Fragen Alle anzeigen
idea how to added a sata hard drive to a power book!
i was thinkin of getting a (2.5 sata to 2.5 ide adapter)
http://www.amazon.com/2-5-inch-SATA-Driv.... do guys think that it would work,i know space would b a issue but i cross that 1 when am there
http://www.ebay.com/itm/7-15P-Serial-SAT...
http://www.ebay.com/itm/2-5-SATA-SSD-HDD...
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
I don't believe this is possible because of the space issue you mention. I am including a link to the hard drive replacement and ask you to pay particular attention to step 12. You will notice the drive is connected to the logic board by a short cable that would be out of position even if the adapter didn't short out the logic board. I would suggest staying with the IDE drive. Good luck whatever your decision.
PowerBook G4 Aluminum 15" 1.5-1.67 GHz Hard Drive Replacement
War diese Antwort hilfreich?
Bewertung 3
As rj713 said, space would definitely be an issue. However, have you thought of perhaps adding a SSD instead? http://eshop.macsales.com/shop/SSD/OWC/M...
Another idea would be to remove the superdrive and replace it with a sata drive. Doing a quick google search came up with MCE's optibay http://www.mcetech.com/optibay/ as an option. Theoretically, I would think you could probably also get away with an atapi to sata adapter.
Just my 2 cents. Best of luck!
Bewertung 1
Antwort hinzufügen
wooly wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 651
