Standby light blinking. Tv will not turn on.
tv just shut off randomly. No power surge. Standby light continuously blinking and tv screen will not turn on. Lightly tapped the screen and seems as tv is off.
Update (02/06/2021)
possibly picture of the problem with connection
Ist dies eine gute Frage?
11 Kommentare
Hi buchta14,
Have you tried opening your TV yet?
LED strips in Samsung TVs are often the culprit why the TV is not turning on.
It you have a multimeter, you can test if the LED strips are powered or not and also is the individual LEDs are working. Sometimes all it takes, is one LED shorts and it prevents the TV from turning on.
von honakrisi
@honakrisi When I moved my tv to a different room to test it I actually did just notice that the screen is turning on and off. Will not stay on though just flickers on and off until I unplug it
von buchta14
Hi,
Does it display the Samsung Logo and then turns off of just flickers for a second and then off?
Unfortunately you might have a bad LED or two on one of your strips but to check that you need to take your TV apart. It is not difficult but you should always take precaution as you could get electrocuted quite easily.
The issue could be anywhere. These new TVs have built in LED drivers in the power supply so if it goes bad, sometime you need to buy a new panel.
Could be the LED strips which are at fault, those are the cheapest to replace/repair.
Or it can be the main board which again is replaceable but also cost heavy. Especially with newer models.
von honakrisi
Yeah displays the Samsung logo then turns off. I have it apart and was leaning towards the power board and have found one for a decent price. Just not 100% sure @honakrisi
von buchta14
Just curious .. if it was one of the led strips would the tv not just always be off and not flicker like it is ? Seems as if it’s just going through the startup sequence then stops and restarts. Doesn’t turn completely on as it is a little darker than normal but I just assumed cause it’s shutting off so quickly. @honakrisi
von buchta14
6 weitere Kommentare anzeigen
