Zum Hauptinhalt wechseln
Veröffentlicht am 26. Oktober 2018. Modelle A1984, A2105, A2106, A2108. Erhältlich als GSM oder CDMA / eSIM, Nano-SIM oder Dual-SIM / 64, 128 oder 256 GB / Schwarz, Weiß, Blau, Gelb, Koralle oder Rot. (Ausgesprochen "iPhone 10 R.")
20 Fragen Alle anzeigen
iPhone keeps going into dfu mode after restore
Hi there, I’m having trouble with an iPhone, Its the XR, When you connect it to iTunes/3U tools the phone is recognized by both as being in DFU mode, When you click on restore/update the phone begins to restore, when its completed and reboots it goes straight back into DFU mode, I have tried to take it out of DFU mode with no joy, I’m hoping someone has come across this before. Thanks.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
same problem any solution
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Does the phone came in contact with liqiud ? If not try to connect your iphone to Itunes or 3U Tools with a disconnected cam and screen, only connected to your logic board is dock connector and battery and then do the update/restore. After the update/restore you can connect the screen, camera etc one by one so you know where the fault is.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thank you for your reply, I have had a look inside the phone and it does not look like it has any liquid damage, I will try what you said and let you know.
von
/am facing the same problem any solutions?
Bewertung 0
Antwort hinzufügen
James Cairns wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 170
