Instrument lights go out and a click at the fusebox would lead me to belive that it is either a relay or a starter issue.
Performing the starter relay test.
(3) Perform a visual inspection of the starter/starter solenoid for corrosion, loose connections or faulty wiring.
(4) Locate and remove the starter relay from the Power Distribution Center (PDC). Refer to the PDC label for relay identification and location.
(5) Connect a remote starter switch or a jumper wire between the remote battery positive post and terminal 87 of the starter relay connector.
(a) If engine cranks, starter/starter solenoid is good. Go to the Starter Relay Test.
(b) If engine does not crank or solenoid chatters, check wiring and connectors from starter relay to starter solenoid and from the battery positive terminal to starter post for loose or corroded connections.
Particularly at starter terminals.
(c) Repeat test. If engine still fails to crank properly, trouble is within starter or starter mounted solenoid, and replace starter. Inspect the ring gear teeth.
STARTER RELAY
WARNING: CHECK TO ENSURE THAT THE TRANSMISSION IS IN THE PARK/NEUTRAL POSITION WITH THE PARKING BRAKE APPLIED. THIS MAY RESULT IN PERSONAL INJURY OR DEATH.
RELAY TEST
The starter relay is located in the Power Distribution Center (PDC) in the engine compartment. Refer to the PDC label for relay identification and location.
Remove the starter relay from the PDC as described in this group to perform the following tests:
(1) A relay in the de-energized position should have continuity between terminals 87A and 30, and no continuity between terminals 87 and 30. If OK, go to Step 2. If not OK, replace the faulty relay.
(2) Resistance between terminals 85 and 86 (electromagnet)
should be 75 ±5 ohms. If OK, go to Step
3. If not OK, replace the faulty relay.
(3) Connect a battery B+ lead to terminals 85 and a ground lead to terminal 86 to energize the relay. The relay should click. Also test for continuity between terminals 30 and 87, and no continuity between terminals 87A and 30. If OK, refer to Relay Circuit Test procedure. If not OK, replace the faulty relay"
Hope this gets you started. You can download the service manual from here Good Luck.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
14
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
13 Kommentare
You replaced the fusebox and the computer due to this error?
von oldturkey03
I've owned a Dodge Caravan and Chrysler Cirrus...both problems I had with these vehicles were the same problems. Transmissions and Emissions. Best bet is to check those out first. I will never buy the brand again. Oh ...I also drove the brand Chrysler and Dodge for a delivery service and his vehicles kept breaking down all over the state as well. Try Chevrolet or Ford.
von Orlando
I'd like to intervene, if that's ok? First, where was the computer located? Behind the front bumper cover or under the hood close to the radiator support? The starter relay could be swapped out with the a/c compressor relay. Did you try that? The click could be the asd relay or the starter relay. They would both need to be working correctly to run, but the starter relay must work for it to turn over. Check that. They are labeled, it should be an easy test.
von Tradesman
I would like to add but not sure if this will help everyone. I got the caravan working that would not start and security system seemed to be the issue. I found a video on youtube where the wires in the harness melt together. they were not melted together but were starting to and I pulled them apart. where the wires are. if you look behind the igniton coil. you can follow the wire harness and you will see wire cover that looks more like a Velcro cover not tape. I pulled the Velcro cover off and pulled the wires apart and the car started and I think I will need to tape the wires separate to insure that they wont get In contact again. I hope this helps. for what the dealer wants to charge and never find this. don't waste your money unless they can tell you what this problem is. why they don't have a bulletin about these wires melting together is beyond me. they need to recall this issue and just replace the cover or tape them a different way
von adam truesdale
I forgot about this post sorry I didn't update sooner. the problem was a bad wire under the battery tray. took awhile for another shop to find the wire and then took less then 5 bucks to fix the connections from what the owner told me. wish I could investigate it more but the lady is driving it all the time now. seems there was some recalls on these minivans for wiring issues. so call the dealers to find out if yours has been recalled.
von adam truesdale
8 weitere Kommentare anzeigen
