Zum Hauptinhalt wechseln
The Buick Enclave is a full-size luxury crossover SUV launched in 2007. The Enclave, the GMC Acadia, and Chevrolet Traverse all share the GM Lambda platform. The Enclave was previewed as a concept car, making it the first Lambda vehicle to be displayed.
radio jumps to aux mode
I notice my Aux cable connector is loose and the radio frequently changes modes by itself jumping radio stations to Aux Mode on the radio display. Any advice how to fix this?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare
I drive a dodge journey 2017 and my radio keeps changing over to aux while I drive it I know I need to check it but can I still drive my car.
von
@christianw96245
Have you checked that there's nothing connected to the aux jacks in the rear of the centre console that may be triggering the change?
If you have the remote control unit for the radio try removing its battery or leave it out of the vehicle in case it is a faulty button on the remote
Aside from the annoyance whilst driving it is still safe to drive the car.
von
No nothing is hooked in the part were a auxiliary cord goes in
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi,
With a lot of radios the aux input socket has an internal contact which is operated when the aux cable plug is inserted. This sends a signal to change the input source.
Most likely if the socket is loose the contact connection or the wiring connected to it, is touching something that it shouldn’t, simulating a cable being inserted.
The radio would need to be removed from the dash and opened and the socket checked and made secure again or if broken then replaced.
What is the year model of the vehicle and is it the stock radio or after market one?
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
My deck has no aux socket i found it as a lose wire in the dashboard behind the deck
von
Did u still drive it
von
Antwort hinzufügen
Alex Lima wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 2,517
