Zum Hauptinhalt wechseln
Repair and information guide for the Samsung RB217AC** refrigerator—a bottom freezer model without an ice dispenser, featuring both drawer and door access to the refrigerator section, and utilizing automatic defrosting and an anti-sweat heater switch. This page covers information for model numbers matching the pattern RB217AC**.
Ice tray not completely filling
Hi
i have a Samsung RS21 fridge freezer
the ice maker seems to be functioning but is only partially filling with water. Enough to fill just 2-4 squares.
I’ve checked the water pressure into the fridge and that seems good and the water comes out at a good oressure
it just seems as though the water to the ice maker cuts off too soon.
it is a second hand FF so not sure how long it’s been like it
many thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi,
Here’s a section from the service manual that shows the value settings for the ice maker’s different fill times and temperature sensor options.
I think that to access the settings you have to press Power Cool and Freezer Temp simultaneously. Hopefully then there are prompts as to what to select as the manual isn’t that specific
Hopefully this is of some help.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Worked a treat, thanks so much.
von
Antwort hinzufügen
Ryan M wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 22
Insgesamt: 1,260
