Zum Hauptinhalt wechseln
Verständliche Reparaturanleitungen für alle tragbaren Tablets von Apple. Reparaturen erfordern Wärmezufuhr und vorsichtiges Hebeln.
5765 Fragen Alle anzeigen
Horizontal lines on the screen after replacing the battery.
I replaced the battery of my 2015 iPad Pro (A1652).
Everything is working great but the top 2cm of the screen are now broken and it’s only showing horizontal lines.
At first, not even the touchscreen was working but I fixed it by disconnecting and connecting it again.
That makes me think that maybe the lines on the screen could be a connection problem between the screen and the logic board instead of a broken screen.
Can somebody with actual knowledge tell me if that is possible?
I was extra careful when I was detaching the screen (I even used a hair dryer) so I’m pretty sure that I did not break it… Although I’ll trust you if you tell me that I did haha.
Maybe I overheated the screen? Idk… send help :’(
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hi,
the LCD’s for ipads are really easy to break, as you have to remove the glass and that could damage the LCD. It’s rare that a battery could cause lines, but it is possible. If that’s the case, just disconnect and reconnect the lcd a few times. If that’s not fixing it, it’s likely you damaged something on the LCD.
Have a good day
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Juanpi Briones wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 246
