H3133 replacement motherboard. Are they interchangeable
I'm trying to track down a h3133 motherboard. I'm seeing alot of motherboards for the phone, however they're not h3133, will they fit and work as a replacement part?
Ist dies eine gute Frage?
I replaced the motherboard on my note 9 and the numbers didn't match but it worked make sure they are the same shape and that it has the right connectors before you buy if you are unsure ask the seller if it can replace your board they'll tell you if it's good for your device or
War diese Antwort hilfreich?
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 10
Insgesamt: 232
