Zum Hauptinhalt wechseln
Repair information for the Sony Bravia 42" LCD TV. Released in 2012. Model number: KDL42EX440.
22 Fragen Alle anzeigen
Why is there a vertical purple line in the middle of the screen
Tv worked fine until I put it screen down on bed to attach wall mounting device for wall mount, once I put it on the wall mount and powered it up this purple vertical line appeared in middle of the screen.
Ist dies eine gute Frage?
Bewertung 2
2 Kommentare
Same exact scenario except for mine is the Sony Bravia XBR-65X850F. It happened when I was mounting the tv and holding it by the bottom when the flimsy bottomade a crack noise. So lame... I'm considering taking it apart to see if unplugging and replugging the cables helps, but I'm guessing not ☹️
von
@riddlen "flimsy bottomade a crack noise." with a subsequent line sure sounds like a broken LCD. We'd have to see this to verify it.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Sounds like you have damaged your panel / screen.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
ed_ruggiero wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 11
Insgesamt: 586
