Zum Hauptinhalt wechseln
2.0GHz, 2.3GHz, oder 2.6GHz quad-core Intel Core i7 Prozessor (mit Turbo Boost bis zu 3,8GHz) mit 6MB geteiltem L3 Cache.
580 Fragen Alle anzeigen
Mac gets really hot above the keyboard
My Mac gets really hot, so much so that it can’t be touched. The hot spot is just above the keyboard close to the hinge. I took the back over off and turned the Mac on and the area in the circle is the hot spot. It becomes that way almost immediately after the computer comes on. Both the fans are running.
What is that area and what can I do about the heat?
Thanks,
Mike
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
4 Kommentare
Thank you!
I have ordered new heat sink and battery and replace them. Including, of course, a thorough cleaning.
thanks again for your help
von
@mike - Why are you replacing the heat sink??
We both recommend cleaning the old thermal paste off and applying a fresh coat.
von
@danj Since I have replace the battery and that has to come out any, I just decided to replace it rather than clean it. Just the way I am I guess.
Thanks for your help.
von
@mike The dust buildup is very easy to clean with a small paint brush, The amount of thermal paste which would need cleaning off is not that big a deal and you would still need to clean the chip surfaces CPU (and GPU if yours has it) as well, not really saving anything here MacBook Pro 15" Retina Display Ende 2013 Kühlkörper Austausch
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
There seems to be a lot of dust in your MacBook Pro. I would dust it off with compressed air, remove the heatsink, replace the thermal paste, clean the fans and the fins at the fans output. Also, looking at your photo, the battery is bulging so you’ll need to replace it.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Yes! I agree! Dust built-up is a system killer! You'll need to clean your system fully and refresh the thermal paste. The battery is in tough shape and needs replacement ASAP as well !!
von
Antwort hinzufügen
mike wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 10
Letzte 30 Tage: 54
Insgesamt: 1,585
