Zum Hauptinhalt wechseln
Ein Desktop Computer ist stationär und in einem Gehäuse untergebracht, getrennt von Peripheriegeräten wie Maus, Tastatur und Bildschirm
542 Fragen Alle anzeigen
Why is my screen black and continues loading
When i started my pc it was loading windows but then a black screen showed and was loading
When i f8 repeatedly upon booting it showed this and after a few minutes it shut down by itself
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare
Are you able to get into the BIOS/UEFI screen? You don't state what model your desktop/mainboard is so I can't tell you which key to press. Often <Esc> or<Del> (ignore angle brackets).
von
Oh yes i can
Next what should i do?
von
@anonymous34
Is the BIOS the latest version? Go to the web site of motherboard manufacturer and see what the latest version is.
It would help if you state which model your desktop computer if a branded or the motherboard model if a component system - you or some one else built it from scratch.
BIOS's usually have a default setup selection but I need details above to help you.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
@anonymous34
If you can boot into the BIOS/UEFI screen then it sounds like a driver issue - especially for graphics, but could be other.
Try booting in Safe Mode:
https://www.digitalcitizen.life/4-ways-b...
Does it work? If yes then fairly certain it is a driver problem. Go into the Control Panel and remove the Video/Graphics card driver and reboot. Download the latest drive for your GPU and install it.
War diese Antwort hilfreich?
Bewertung 1
5 Kommentare:
Now i encountered a new problem.
The screen display no signal.
I plugged the cables correctly.
von
@anonymous34
Nothing whatsoever even in BIOS screen?
von
It seems like the problem is either my motherboard or my processor.
Thanks for replying though.
von
@anonymous34
Does anything happen? Fans, lights, power supply,hard drive, RAM, etc. What about the video card?
Very rarely does the CPU or motherboard fail. We need more details about your computer in order to help. What make, model, etc. Take the side panel off and look inside. Are any fans spinning?
von
Yes all of the fans are spinning.
I watched a video on how to troubleshoot my pc.i only connected the important parts of the pc and i found that it is either the motherboard or processor. As i don't have another motherboard i can't tell what is the real problem
von
You may try entering Safe Mode to fix this problem. Or do a system repair with command bootrec.exe in cmd after entering Safe Mode or booting with a Windows installation CD.
https://www.minitool.com/partition-disk/...
Bewertung 0
Antwort hinzufügen
izhaar wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 57
