Zum Hauptinhalt wechseln
Verkaufsstart Juni 2012, Model A1278. Intel Prozessor mit Turbo Boost
1624 Fragen Alle anzeigen
Where is the C7292 on a A1278 board?
Hi all,
can someone please help me. I’m trying to find the C7292 on the logic board and as I don’t have the use of another laptop I’m having trouble viewing the schematic of the board, as I only have my iPhone.
the serial number:
C0742301XRF1YME3
please can someone show me where the C7292 is please.
Update (03/23/2021)
Thanks Allen, I realise that some info that I gave was incorrect. Sorry about that I’m new to this. But I’m ok at soldering.
thanks for your patience, your help is much appreciated
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
9 Kommentare
take some pictures of the board. that would prove to be helpful
von
How about giving us a bit more here why are you looking for this cap? Can you fill us in on what led you to this.
Can you at least give us your board number 820-xxxx
von
@paul smith the picture you uploaded is SUPER blurry. also as Dan said why do you thinkk you need to replace this?
von
It’s regarding this post of mine earlier
http://send.ifixit.com/ls/click?upn=fK8B...
I got an answer but as I don’t have access to another laptop I can’t find this cap.
Thanks
von
@smudger_1767 - I really need the board number as you've jumped to a different system here.
von
4 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
OK, let’s verify what you have. Look around the fan edge of the logic board you should see this
Is that what you have?
Update (03/24/2021)
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
Hi
I have put all of the numbers that I can find in the logic board on my first post. I just want to find out where can I jump pins 1 and 2
von
@smudger_1767 - Paul I want to help you! But blindly shooting still again won't help you. Apple alters the layout of the logic board often between models so while the shape of the logic board is the same and even the placement of a connector as in this case, the trace routes are often moved about!
So I'll give you one of the 13" model versions Apple used in this series (there are two) hopefully it's the right one.
von
@danj the board number is 820-3115-B
von
I did a search for 7292 in a PDF of the schematics for the MacBook Pro (13-inch, Mid 2012) and it returned no results. Also couldn’t find it by using board view software. Are you sure there’s a component labeled C7292 in the schematic?
Bewertung 0
2 Kommentare:
@zpl - I may have mis lead @smudger_1767 I might have grabbed the wrong board.
von
I think there might've been a mistake - the previous post made by this user listed a MacBook where as here it lists a MacBook Pro. Oops!
von
According to your logic board serial number, The EEE code for your board indicates that it is a Mid 2012 (2.5GHz Core i5) You should be able to see 820-3115-A silkscreened on it. This board does not have have C7292.
Check you are not looking at the schematic for anything else but a 820-3115.
The components will be in the following area. Underside near the RAM slot. See photo
Bewertung 0
Antwort hinzufügen
Paul Smith wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 114
