Zum Hauptinhalt wechseln
600-1500 Watt induction cooktop. Released since at least 2015 (guessing from the date inside the appliance) to at least 2019. Labelled PicGold 3 inside.
1 Fragen Alle anzeigen
ERROR 9 and some burned components.
I blew a fuse and replaced it with the same type. When plugging back in, heard a pop and it now reads E9. The board inside shows Resistor 1 to appear toasted and and more black evidence around a multi leg connector. I can't find schematics and can't read the value of the resistor--any ideas?
This multiprong connector had evidence of burning on the other side. Is this a component or just a junction? I would like to test it.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
if u zoom all the way in it almost looks like the numbers are 4731
https://www.mouser.com/ProductDetail/Vis...
https://buyaircraftparts.com/part-number...
War diese Antwort hilfreich?
Bewertung 1
The second device is an insulated-gate bipolar transistor (IGBT) a three-terminal power semiconductor device primarily forming an electronic switch. There seems to be a good deal of heat damage in that area, so unless you feel competent tracing circuits, can solder WELL, have experience working with SMT (surface-mounted components), and can use a meter, I'd leave it to a professional. This device has a great deal of current running through it and a hack repair could cause a lot of trouble...like electrocution or a fire. You could replace the board, but the replacement could run you the price of a new unit. What caused the fuse to blow? What were you doing at the time? Fuses blow when there's a short, or the circuit draws more current than it should, which could be for a number of reasons. Did the damage occur before or after the fuse was replaced. Did the unit overheat? There could be more damage than is apparent. Seriously, I know it's tempting to want to tinker, but this isn't the type of device to screw around with unless you have a lot of experience troubleshooting and repairing high-current equipment.
Bewertung 0
Antwort hinzufügen
T N wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 22
Insgesamt: 474
