Zum Hauptinhalt wechseln
Repair guides and support for all-in-one washer and dryer assemblies as well as stacked units.
139 Fragen Alle anzeigen
My dryer does not heat up
I bought a Kenmore stackable washer/dryer second hand. The timer did not work on the dryer and other than that the unit worked fine. The dryer started getting really hot when on and then all of a sudden does not heat up anymore. The dryer barrel still turns and there is just no heat. Model No. 110.88752792
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi,
Check that the hi-limit thermostat, part #19, dryer bulkhead parts diagram is OK.
There is also an operating thermostat (see part #5, dryer bulkhead parts diagram) which should regulate the temperature, that may also be worth checking.
The hi-limit thermostat is a safety device that prevents the dryer from overheating and causing a fire so maybe the operating thermostat is also faulty.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
russedj wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 62
