How to install chinese language in n8?
i got a n8 and it cannot show chinese language,how can i install myself?
Ist dies eine gute Frage?
You can check and see what language are available to you by
Select Menu > Settings and Phone > Language .
Change the device language
Select Phone language.
Change the writing language
Select Writing language.
Activate predictive text input
Select Predictive text.
If you do not have Chinese in the option, then you need to have the language pack containing Chinese installed at your local Nokia Care Point. Problem is that you will lose this language pack everytime you update the firmware. The phone will always revert back to its original language pack.
Hope this helps, good luck.
War diese Antwort hilfreich?
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 3,998
2 Kommentare
how to install chinese language in Nokia N8
von Tenzin
check out old turkey's answer.. if you want more help then you should start your own question.
von pollytintop
