Zum Hauptinhalt wechseln
Vorgestellt am 16. September 2016. Modelle A1661, A1784 und A1785. Verfügbar mit 32, 128 oder 256 GB internem Speicher in den Farben Rose-Gold, Gold, Silber, Schwarz, Diamantschwarz und Rot.
1364 Fragen Alle anzeigen
Main back camera works fine, but no 2x camera and no Flash
The camera app opens fine and works well at 1x zoom, but the telephoto 2x mode cannot be accessed when I press 1x, no matter what I try to do on the software…. Also, the flash doesn’t work, as well as the flash light. Any ideas on what I can do, or what might be wrong?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
The x1 and x2 are two separate cameras, perhaps the x2 unit is faulty. You would need a complete new camera unit as you cant just replace one of the cameras. The flash is attached to the volume buttons, mute switch and power button. If they are working then its just the flash which is faulty and the flex will need replacing. I hope this helps.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
KAVA KONNECT wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 34
