Zum Hauptinhalt wechseln
Released in 2006, the 19" Dell Ultrasharp 1907FPc is a solid budget LCD monitor with four USB 2.0 ports, as well as VGA and DVI inputs.
3 Fragen Alle anzeigen
The monitor has display problems
A friend of mine’s computer monitor tends to flicker rapidly and display lines on the top of the screen with the section above this being normal, but the area below significantly higher in brightness. The flickering tends to go away after a few minutes. Can you tell me what the problem with the monitor is? I’m guessing an issue with the graphics card, but it could be something else. Thank you!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hey Michael,
Without more detail, kind of hard to say, but I think you are on the right track. If it isn’t a physical connection or the screen itself, it is probably a driver issue.
Hope this helps.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Michael Deitz wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 92
