Zum Hauptinhalt wechseln
Apples Top-Smartphone für 2020. Das iPhone 12 Pro Max wurde am 13. Oktober angekündigt und am 13. November veröffentlicht. Es verfügt über ein 6,7-Zoll-OLED-Display, ein dreifaches Rückkamerasystem mit LiDAR und 5G-Konnektivität. Nachfolger des iPhone 11 Pro Max.
110 Fragen Alle anzeigen
Does the camera have anything to do with flash?
My iPhone 12 Pro Max fell from me, and the camera broke and did not work, and the flashlight also does not work, but I do not see any defects in flashlight, and I want to order the camera from outside the country in which I am in. Do I need to order the flashlight also?  Or is it that when the camera is not working, the flash will not work as well?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
The rear camera assembly and flash light are different components. Just be aware that when you change the cameras in the 12 series, it will display a message saying “Apple is unable to verify this is a genuine camera” upon turning the device on, even if you purchased another 12 pro max from an apple store and swapped the parts, it will still display that message. Don’t worry, it will not hinder the performance or usage of the device. It’s basically there to tell you, “hey your device has been opened or repaired.” Don’t let the message scare you. As long as you do the repair right, the camera should work just fine. Similar messages appear whenever you change the screen and the battery as well. Also keep in mind that when you open the device, you will permanently lose liquid resistance. You should replace the seal but even then it’s not quite as good as OEM so make sure you keep it away from liquids as best as you can. Use acetone and some Q-tips to clean the frame so the new seal can adhere better.
War diese Antwort hilfreich?
Bewertung 0
If I changed the camera, the flash will work or not?
Bewertung 0
1 Kommentar:
Flash will work no issues. It isn't dependent on the camera module, Flash and Power button are interconnected so as long as your Power button is working your Flash also should be working fine!
von
Antwort hinzufügen
Abdulmalik wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 9
Insgesamt: 407
