Zum Hauptinhalt wechseln
Die Neuauflage des Apple 13" MacBook Air von April 2014 wurde mit Dual-Core i5 und i7 Prozessoren aufgefrischt. Die Akkulaufzeit wurde etwas verbessert.
313 Fragen Alle anzeigen
Keyboard and Trackpad only work in Diagnostic mode
After liquid damage to the MacBook Air, I’ve been able to get it nearly operational with a lot of cleaning w/ isopropyl alcohol & contact cleaner. However, I cannot get the trackpad or keyboard to work. I replaced the ribbon cable with one from iFixIt and now the trackpad & keyboard only work in Diagnostic mode.
Weirdly enough, the caps lock light is always on and remains on if I boot into macOS or Recovery mode. If I hold D when booting, I can get into diagnostic mode & can press caps lock to turn the light off. The trackpad functions in this mode.
I’ve reset PRAM and SMC multiple times. Any help on this would be greatly appreciated. Thanks.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
What is the errors (if any) you got in diagnostics?
von
@danj No errors at all since cleaning the entire logic board w/ isopropyl.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
You likely need a new Trackpad and/or the trackpad cable.
This series uses the Trackpad to carry the keyboards signals to the logic board via the combo cable.
MacBook Air 13" (Mid 2013-2017) Trackpad Cable Bild
Produkt
$14.99
MacBook Air 13" (Mid 2013-2017) Trackpad Bild
Produkt
$49.99
War diese Antwort hilfreich?
Bewertung 1
6 Kommentare:
But then why would the trackpad work fine in Diagnostic mode? If this was a hardware failure, the trackpad and keyboard wouldn't work at all.
von
The trackpad is the junction of the two signals which then go to the logic board. I often find liquid gets to the connector area damaging it or the circuity on it gets damaged. Time to replace both!
von
@macstainless - So what was it the cable or the trackpad?
von
Was both. I have no idea why it would only work in Diagnostic mode but swapping both out got it up and running. Thanks for the input!
von
Oh, this sucks.
I had just posted on another Ifixit post that I too was seeing the KB/Trackpad work in diagnostic mode and was optimistic it was not a HW issue and was next going to try an OS install.
At almost $100 to fix this with replacement parts, it seems another used Macbook would be more cost effective.
Especially since the 128GB storage is getting hard to maintain anymore.
Knowing me I'm still going to try the OS re-install on a separate disk, I'm a sucker for punishment that way.
von
1 weiteren Kommentar anzeigen
Antwort hinzufügen
Aaron wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 339
