Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
Is there any way I can pop my screen back into the phone?
Recently I had my phone fixed and a few days ago, when my phone was dead I dropped it…It lead to my phone’s left side of the screen and top part to be loose and unattached. I don’t know if I should attempt to put it back into place as it is quite risky.What should I do?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
I would take it back to wherever you had it fixed to have them address it. I’m wondering if maybe your battery has started to swell which would typically cause the left side of the screen to pop up. You could try to pop it back into place but you run the risk of either damaging the display or if the battery is in fact swollen, you run the risk of shorting or puncturing the battery which can lead to severe burns as seen from the Note 7 fiasco.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Unknown Gamer wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 69
