Zum Hauptinhalt wechseln
The JBL Flip 5 is a small portable Bluetooth speaker, released in August 2019. It offers an IPX7 rating for water resistance and up to 12 hour battery life. Model: TT
31 Fragen Alle anzeigen
Can’t turn on,
Can’t turn on, when plugged to charge it turn on immediately by self but can’t control, can’t connect . When unplugged it immediately turn off by itself also
Do you know what is issue?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
I have the same problem. What's the solution?
War diese Antwort hilfreich?
Bewertung 1
its in demo mode?, if i remember press and hold the Power button and play button simultaneously until it turns off, then you can turn it on and do a reset by pressing play and volume up button until it turns off, then you're good to go.
Bewertung 1
2 Kommentare:
That didn’t work for me now what?
von
After a few tries, I was able to fix it with this tip! Thank you 👍🏻
von
Bewertung 0
1 Kommentar:
Any progress on that problem? I'm having the same problem now.
von
Antwort hinzufügen
Yeng Nith wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 21
Insgesamt: 2,006
