Zum Hauptinhalt wechseln
The QiCycle Folding Electric Bike is Xiaomi’s first foray into the world of e-bikes. It has a 250W high-speed motor powered by Panasonic 18650 lithium batteries. The Shimano Nexus 3-speed gear hub in combination with the torque measurement sensor gives you up to 45km bike power on a single charge. It also has a trip computer can connect to your smartphones via their special app and is–of course–foldable.
Error code 00008 in display - where to look for
Just after a few days usage the bike shows an error when I start the computerdisplay.
I suspect a sensor/cable not working but without repair manual it is hard to know where to start. The owners manual does not mention any error codes?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
No unfortunately. I had to send it back to the seller and they could not figure out…so they refunded me. I loved the bike so might buy another of I can find a seller that does service the bikes.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Well, I had two bikes and the second bike gave the same error an I solved it: Is is the engine disconnected error.
What happened is that the steer and frontwheel were turned backwards and that put stress on the engine connector, and it csme loose. It is located inside the left stem of the fork, you can see it if you look from the right side in.
I had to remove a little clamp and was able to rejoin the connectors and the error dissapreared. In stead of putting the clamp back, I used two tiewraps to fix the cable on the stem so I can easily remove the tiewraps and reach it when I am not at home.
von
Hilfreichste Antwort
Picture of the motir connector in the fork:
Bewertung 1
Hi Frans, since I have the same problem i hoped you fixed it?
Bewertung 0
1 Kommentar:
this motor cable connector came loose (left stem fore fork)
von
Antwort hinzufügen
Frans Dijkstra wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 24
Letzte 30 Tage: 74
Insgesamt: 2,407
