Zum Hauptinhalt wechseln
Ein Desktop Computer ist stationär und in einem Gehäuse untergebracht, getrennt von Peripheriegeräten wie Maus, Tastatur und Bildschirm
327 Fragen Alle anzeigen
Desktop monitors, tried 3, wont turn on after computer froze.
Weird sound then short electrical hum. Screen froze. Manual computer restart. Can hear it but monitor is black. Monitor check on another computer. Monitor is fine. Checked cables. Blew out dust. Tried different graphics card and nothing. Monitors - tried 3- still wont come on. Which hardware part could have blown?
Ist dies eine gute Frage?
Bewertung 3
2 Kommentare:
Hi Helen,
Which model especially the actual mainboard model name and number . Will most likely be printed right on the circuit board.
Also CPU if you know which one.
With that information we may be able to help you.
There are many possible solutions.
von
2 things come immediately to mind. Does your PC go through the entire boot process? By that, I mean, your fans turn, lights flash and the pc runs the BIOS that checks all the hardware(pc, memory, floppy, HD,CD/DVD and video. If your video is misconfigured in your BIOS, it could cause this problem.
Can you get into your BIOS to check this problem?
von
Einen Kommentar hinzufügen
1 Antwort
Change psu, reset bios see if it works, check for visual damage on MB, use new 3v coin battery. Try leting system sit for a while with no 3v bat & -/+ shorted with a cable. See if with no ram or CPU the system beeps. If all fails could be a short/chip or vrm from MB.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Helen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 46
