Zum Hauptinhalt wechseln
Reparaturanleitungen und Support für das Lenovo IdeaPad 310-15IKB, ein Mittelklasse-Laptop, der 2016 auf den Markt kam.
HDMI port repair (general question)
Hi there!
So the HDMI port on my laptop stopped working, and a USB to HDMI adapter does have a terrible framerate. Its not a good solution.
The question is, how hard is the fix. Is it even possible to just replace/re-solder the old port? I did not find any good guides - i would make one.
Just need some motivation here ^^
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Soldering a motherboard requires experience. It could irreparably damage the board and you should buy another one. If you have experience, look at where the connector is located and if you have small components nearby. It is one of the easiest parts to change in this type of repair.
Lucky!
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
It depends on whether you HDMI port is on a daughter card, or part of the motherboard. If it is on a daughter card, then repair is often simple and you can just replace the pcb. But if the problem if with the motherboard (like with the hdmi controllers, or if the hdmi port is soldered directly to the motherboard) then it might be more difficult.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Prokrastinator wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 21
Insgesamt: 692
