Zum Hauptinhalt wechseln
Magnetischer AC-Netzadapter der 2. Generation für MacBook-Produkte, erstmals 2012 veröffentlicht. Nicht kompatibel mit Systemen der vorherigen Generation. Erhältlich in den Versionen 45 W, 60 W und 85 W.
2-Prong Pin loose, causing intermittent connections
One of the prongs for my charger is loose and it’s causing the charging connection the cut in and out. The cable is in great condition and my port has nothing stuck in it, so I know it’s likely not those.
I have attached a video showing the loose prong. It requires me to plug in A/C cable very carefully, as fully inserting it disconnects the power. The issue occurs whether I use the duckhead adapter, Apple extension cord, or any 2-prong power cord
is this easily fixable? I would hate to just throw this away
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Sadly, there is a point when its just smarter to replace the charger, this is one of the cases. ;-{
You could try getting some glue where the pin fits in. I’ve had mixed success.
Make sure you get a REAL Apple unit as many of the Amazon or eBay units are knockoffs which can damage your system!
The real MacCoy! Apple.Com - MagSafe Power Adapters
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
David Chun wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 17
Insgesamt: 1,547
