Zum Hauptinhalt wechseln
Verkaufsstart Juni 2012, Model A1278. Intel Prozessor mit Turbo Boost
1624 Fragen Alle anzeigen
Can I fix a broken connector housing/mount?
I was trying add new thermal paste and when I was removing the logic board, I accidentally cracked and then broke off one of the connectivity housing that (I think) goes to the disc drive. The cable/wire seems fine. It’s the mount that held the red cable
that is broken. Is this part replaceable/repairable? I’m having trouble finding a part that would match. Any ideas? Thanks
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
It’s the socket for the left speaker similar to the fan socket. It can be soldered back to the board if you find the part. You can harvest it on a Macbook donor board or buy it on eBay. Any tech can solder back the socket for cheap, only six micro solder to do on this part. Don’t try to glue it on the board, the 4 front pins must make a good contact to the pads and only solder can be used in this case.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
MyMusic Nakamura wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 32
