Zum Hauptinhalt wechseln
Die langerwartete Neuauflage des populären MacBook Air mit einem Core i5 Prozessor von Intel, ein verbessertes Retina Display und mehrere andere Veränderungen und Verbesserungen. Veröffentlicht am 7. November 2018.
149 Fragen Alle anzeigen
Can’t use both Recovery modes also can’t boot from usb
So while I was messing around and resizing the partition for windows bootcamp I think I might have messed around and deleted the mac partition. I can’t boot from mac OS only windows. While I press down the option key the macintosh hd icon appears but when I press it, it just starts booting on and off without doing anything. The only solution would be to reinstall mac OS. I have a macbook air 2018 that originally came with mojave which I’ve never really changed or upgraded. Recovery mode doesn’t work at all. Internet recovery mode only gets to the part where I select my wifi and put in the password and it takes a long time for the progress bar to fill to eventually show nothing. I dont have another macbook but I do have a pc with windows 10 on it so I used Transmac to try to make a bootable usb with a mojave installer on it but that didn’t work either. According to Apples website my model has a T2 security chip which means the choice to boot from from an externel drive is disabled but I cant obviously allow it at this point since I dont have access. What can I do at this point I really want to use Mac OS again. I’ll be darned if I have an expensive macbook and the only option is to use windows on it.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
I hope you have a backup of your stuff!
Time to visit a local mac guru who can help you. The T2 systems are very tricky when the drives are messed up. Even I’ve had to throw the towel in on a few passing them over to an Apple Store as they have some special tools not available to the independent repair shops.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Wanda Arvelo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 40
