Zum Hauptinhalt wechseln
Repair guides and support information for RCA-brand tablets.
1307 Fragen Alle anzeigen
Does Anyone Know Where to Get a replacement battery
model ct9223w97; I am looking for replacement batteries. I have found a 3.7V 4000mAH and was wondering if that will work? RCA Support would not answer the question. Anyone here; any info would be greatly appreciated. The original is 3.7V 3750mAH.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
not finding one specifically for that model, the only thing you can go on is voltage, capacity, size and connection. 3.7V 3750mAH is only 1/2 of the requirement. Size is a big issue and connection can sometimes be altered using the connector from the original battery.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thanks, appreciate the response.
von
Antwort hinzufügen
Avery Hines wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 156
