Zum Hauptinhalt wechseln
Guides for the Wi-Fi version of the iPad Mini 4—model A1538. Announced on September 9, 2015, the iPad Mini 4 is the successor to the iPad Mini 3.
97 Fragen Alle anzeigen
The ipad doesnt turn on and gets hot, usb amp meter is showing .95amps
Hi,
Ipad mini4 wi-fi, doesnt turn on , shows 0.95amps drawn gets hot, i removed the sheild and found the series of capacitors around a big chip shorted i guess its vcc line, i do not have enough knowledge about this board as i use phoneboard software and i do not have schematics of the board, i would like to know how do i get to the actual shorted capacitor, also i see with freeze spray that a coil and a diode near the chip is getting hot, i removed them both but the short remained, please help.
thank you !
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
tracking down a short is either visually or by component removal. Sometimes, if you have a sensitive ohmmeter, you can track it down with that. But it must be able to read milliohms.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Is there a way that I can inject some voltage to that line and look for a hot capacitor? I’m relatively new in this field , good with soldering but I suck at diagnostics, any help would be appreciated thank you for your prompt answer
von
Antwort hinzufügen
roman wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 28
