Zum Hauptinhalt wechseln
Veröffentlicht am 16. September 2016. Modelbezeichnung 1660, 1778. Verfügbar in den Versionen: GSM oder CDMA / 32, 128 oder 256GB / Rosé Gold, Gold, Silber, Mattschwarz oder Hochglanz-Schwarz
2264 Fragen Alle anzeigen
Charger port works when part is tested, but not when in the phone?
I just bought an iphone7 to repair and I am a little confused by what this one is doing.
When I received the phone it was stuck in a boot loop and wouldn’t recognise the charger. I disassembled the phone and plugged in only the screen, the charge port and the battery to test it. It booted OK into setup, the phone was charging fine, and it was recognised by iTunes.
I have put it all back together and now the charger doesn’t work again and iTunes doesn’t see the phone.
Setup process works fine until it gets to the Data & Privacy setting and then it hangs.
Will replacing the charger assembly likely help?
Have I mangled something putting it back together?
Has anyone else had this problem?
thanks for your help.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Before purchasing any more replacement parts, take the phone apart again and get it to the state you knew it worked in(screen, charge port, and battery only). If it's not working now, then you've damaged something putting it back together, but if it does work, you can continue to the fun part!
Simply put it back together one part at a time and keep testing it until you run into the problem again, and then you'll have found the part that causing the problem. Sometimes it can be something like a camera that is causing these issues so plugging in each component one at a time will allow you to find out which part is the problem, even if it might take a while to do so...
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Edward Hillman wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 13
