Zum Hauptinhalt wechseln
Reparatur- und Zerlegeanleitungen für die 2020er Neuauflage des MacBook Air. Erschienen im März 2020
103 Fragen Alle anzeigen
MacBook Air 2020 - startup key combinations not working
Hi, I lost the right arrow key.
Now I can't use the Mac startup key combinations like recovery (CMD + R).
How to solve this issue ?
Apple helps me to replace single key? or Arrow Keys alone ?
Laptop Details :
MacBook Air (Retina, 13-inch, 2020)
1.1 GHz Dual-Core Intel Core i3
8 GB 3733 MHz LPDDR4X
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
While loosing the arrow key does need to be fixed in its self it shouldn’t stop you with the startup keys. This sounds like a deeper issue here, did you leave the T2 secure boot feature enabled? About Startup Security Utility
You will need to disable it and/or you have still deeper issues with the keyboard which will need to replace it MacBook Air 13" (A2179, Early 2020) Upper Case with Keyboard
Reference: About macOS Recovery on Intel-based Mac computers
MacBook Air 13" (A2179, Early 2020) Upper Case with Keyboard Bild
Produkt
$249.99
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Thanks a lot for your valuable answer.
I have doubt, if its keyboard issue? How it works fine after login.
After I logged in, I face this issue sometime "Like I selected the icon and keep moving to the right side" I use the ESC button to overcome.
I can't enter into the recovery mode.
von
@iamjayakumars - If its not the keyboard, then its the trackpad and its combo cable or worse! Your logic board.
von
Antwort hinzufügen
Jayakumar Sadhasivam wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 131
