Zum Hauptinhalt wechseln
Dect 6.0 cordless phone system with answering system and caller identification. Repair for this device requires only common tools.
When I make a call, there is a short stutter before the normal ring to
Hello. When I call out, a short stutter occurs before the normal ring tone kicks in. It is not linked to a message issue. It is making me paranoid. Any solutions/explanations, please? Thanks.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi,
You may have to first prove whether the problem is associated with your cordless telephone/base station equipment or the landline phone service itself.
Is the phone’s base station connected to a telephone cable socket or an internet modem i.e. VoIP phone service (voice over internet protocol)?
Try connecting a corded phone (or another known working with no problems cordless phone with base station) to the phone line or modem in lieu of your cordless phone's base station and see if the problem is with your cordless phone system or the telephone service.
If the problem is with the phone service contact your service provider about the problem. If the phone is connected to a modem, check the phone settings in the modem to make sure that they’re correct (usually found on provider’s website)and if so contact your provider.
If the problem is with your cordless phone setup, how many handsets are connected to the base station? If more than one does it occur on all or only the one?
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
Thanks, Jayeff, for your consideration. I have spent time looking for an old phone and have come up empty. However, realising the issue occurred after receiving a new modem, I worked on the theory that Telstra 101 message service may have been the default setting. I disconnected from it - and the stutter has disappeared. Unfortunately, our answering machine no longer records messages, even though it is turned on. Now I have to work on that.
von
Hi @t t
Try setting up the Messagebank service again and then set it to answer calls after an unanswered ringing time which is longer than the answer machine ring time (see p.10 of the phone's user guide for how to set the ring time for the answer machine)
To give you some idea the ringing cycle in Aust. is 3 seconds i.e. 0.4 secs on - 0.2 seconds off - 0.4 seconds on - 2 seconds off then the cycle is repeated. e.g. for the answer machine answer after a ring time of 6 rings = 18 seconds so Messagebank needs to be set for >18 seconds. Perhaps 25 or more to be safe
The idea is that the answer machine needs to answer before the voicemail does.
Here's how to extend the ring time on Messagebank after setup: (I think the default is 15 seconds but I may be wrong. Its been awhile ;-)
Pick up the phone and press *99
Enter the number of seconds you wish the phone to ring before a call is diverted to Messagebank (between 5 and 60 seconds).
Press # and hang up. e.g. *9925# for 25 seconds
If you still get the stutter try the VMWI reset as described on p.9 of the manual
Although having an answer machine negates having to have messagebank if the answer machine is full of messages (none having been deleted) and cannot store any more, at least you won't miss any as the calls should then go to messagebank
von
The reason is your set up on your cordless handset its called flash time change it to at least 100 MS or 110 MS I had same problem and thought my line was connected to someone i went through setting's and i was on 90 MS i changed to 100 MS and dial tone is completely normal now. I think MS stands for milliseconds
von
Antwort hinzufügen
t t wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 18
Insgesamt: 820
