Zum Hauptinhalt wechseln
Die Wi-Fi Version von Apples iPad 6, erschienen im März 2018. Erhältlich mit 32 und 128 GB Speicher. Ausgestattet mit einem 9,7" Retina Display und einem 64-bit A10 Fusion Prozessor.
151 Fragen Alle anzeigen
I just replaced the screen and doesnt work
Hello, I just replaced my screen and digitizer of my Ipad 6th Gen. But now only some parts of the screen are working. Is there a fix for this or send my screen back for another one.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hello Tyson,
In this model, the digitizer is an independent system. Unfortunately, it is led with quite long tapes with a non-grounded signal. During installation, remember that the tape circuits provided for earthing must be glued through the conductive layer in designated places. Otherwise, it causes uncontrolled short circuits to ground or the signal does not reach the motherboard at all. Another (indirect) reason is too strong bending of the connection tapes and, as a result, breaking the continuity or being trapped by the screen.
You'll have to unfold it again and check your work. Alternatively, you can use an experienced repair shop.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
I don’t understand the “earthing” cable part
von
Bob - it mens "grounded" :) (slang)
von
Antwort hinzufügen
Tyson Hall wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 47
