Zum Hauptinhalt wechseln
Die Wi-Fi Version von Apples iPad 6, erschienen im März 2018. Erhältlich mit 32 und 128 GB Speicher. Ausgestattet mit einem 9,7" Retina Display und einem 64-bit A10 Fusion Prozessor.
147 Fragen Alle anzeigen
iPad bootloop after throwing due to Roblox server maintenance.
My iPad got trapped in a bootloop after this story: I was playing a game on roblox, but the server went on maintenance. I threw my ipad many times across the room in anger. It worked fine, but it bootlooped after i came back home. It bootlooped and force rebooting did not help ether. The worst case scenario is the SSD broke and my data and the OS is gone. I think my logic board or bios chip is loose. I do not want to lose ANY data. I did not back up iCloud due to the space being full (5GB) I have 128 GB black model.
Edit: It was just a botched update. No physical damage whatsoever. I have a case.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Just connect to iTunes, and enter Recovery Mode, and hit update. After, open photos and go to the top of it, and charge your device, but keep it on. This will recover all of your photos. It worked for me.
War diese Antwort hilfreich?
Bewertung -1
Hilfreichste Antwort
Fix your stupid anger issue first. If losing some data fixes your tantrum, it’s a cheap solution.
As for the iPad damage, if you need to ask, you can’t do it.
Bewertung 1
2 Kommentare:
I clicked update with iTunes, and now it works perfectly fine,my data intact. Learn some manners. I'm reporting you.
von
@The Mariocrafter So your anger issue will just wreck your iPad next time.
My manners are reserved for sensible people, you do not qualify.
von
Antwort hinzufügen
The Mariocrafter Alt wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 11
Insgesamt: 195
