Zum Hauptinhalt wechseln
Das Samsung Galaxy S3 ist ein Smartphone mit Multitouch- und Drahtlosladefunktion, ist Eyetracking-fähig und hat einen vergrößerten Speicher.
456 Fragen Alle anzeigen
Won't Charge Or Displays Caution Sign During Power On Attempt
I know this is a pretty dated piece of tech, but I have pictures and contacts in the device that I need. I’ve tried different chargers and different plugs, but the result is the same. Changing batteries have given me the results of a black screen or a caution sign inside the “charging battery” animation upon start up. I’m just looking for some help so I can get what I need off of there. If anyone has any ideas I’m open to any and all of them. Thank you.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
I repaired alot of these devices back in the day and the fault you are describing is almost always the Charging Port Flex Cable.
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
What exactly do I have to do to the flex cable? Is it loose or do I need to replace it? And where is it located?
von
@jjmarcus143 Sorry, I thought it was a Galaxy S4 for some reason. Galaxy S3 is just a port, not a flex cable. But unfortunately, I'm not sure what could cause this on this model.
von
Dang. Alright I appreciate the response.
von
Antwort hinzufügen
Jamarcus wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 61
