Dead pixel or stuck pixel on retina screen?
what causes this to happen and will it get worse? dead pixel or stuck pixel?
Update (06/16/2021)
Ist dies eine gute Frage?
Over time the pixel switching elements can burnout. Often during the manufacturing process the glass plate may not get enough metal-oxide deposited or the PNP/NPN silicon or color filter material was not properly laid down. So the given group of pixels in an area of the screen wear out sooner. There is little you can do to fix this type of failure as its age.
A second issue that can create this the defuser sheets which is part of the backlight system get wet which I see here the signs of along the edge of the image area.
I would live with it as its not that bad. It is not likely to get worse as long as you don’t get your system wet again.
War diese Antwort hilfreich?
I’m using lesterine whenever I cleaned my macbook. Is there any possibility that the lesterine itself get inside the lcd because I only put the lesterine on the microfibre cloth and make it wet therefore I can clean the screen.
@admwitchy - Like a sponge squeezing it out will release what it has, so you may have let too much escape when you where near the edge and pressing down could have push it inwards.
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 27
Insgesamt: 818
